This is a problem we are facing: The horizontial scrollbar does not render when the grid height is set. We want these features enabled:
- Grid height of 400px- Fixed Headers- Grid width of 100%- If columns exceed the width, render a horizontal scrollbar.- If data exceeds the height, render a vertical scrollbar.
The example is even broken in your JSFIDDLE.
http://jsfiddle.net/gh/get/jquery/1.9.1/igniteuisamples/jsfiddle-samples/tree/master/EN/HtmlSamples/grid/overview-sample/
Go to the link and replace the grid declaration with the following grid below. You will notice:
- vertical scrollbar is available.- horizontal scrollbar is missing.- Horizontal scrollbar appears if and only if you start to shrink the page by making the browser smaller.
This is a serious problem for us. What work around do you have to fix this issue?
v14.2
IE11 + Firefox
$("#grid").igGrid({ primaryKey: "ProductID", width: '100%', columns: [ { key: "Id", dataType: "number", width: "50px", headerText: "blah", hidden: false }, { key: "LocationId", dataType: "number", width: "50px", headerText: "blah", hidden: false }, { key: "CustomerId", dataType: "number", width: "50px", headerText: "blah", hidden: false }, { key: "OrderLocationId", dataType: "number", width: "50px", headerText: "blah", hidden: false }, { key: "OrderStateId", dataType: "number", width: "50px", headerText: "blah", hidden: false }, { key: "Customer", dataType: "object", width: "50px", headerText: "blah", hidden: false }, { key: "OrderLocation", dataType: "object", width: "50px", headerText: "blah", hidden: false }, { key: "OrderItems", dataType: "object", width: "50px", headerText: "blah", hidden: false }, { key: "ShipDate", dataType: "date", format: "MM/dd/yyyy", width: "75px", headerText: "Ship Date", unbound: true, formula: function (record, grid) { return "test";//return $.ig.formatter(record.Customer.ShipDate, "date", "MM/dd/yyyy", true, true, null); } }, { key: "FreightCarrier", dataType: "string", width: "120px", headerText: "FreightCarrier", unbound: true, formula: function (record, grid) { return "test";//return record.Customer.CarrierDescription; } }, { key: "PaymentType", dataType: "string", headerText: "Pre-Paid / Collect / 3rd Party Payment Terms" }, { key: "LocationNumber", dataType: "string", width: "65px", headerText: "PC #", unbound: true, formula: function (record, grid) { return "test";//return record.OrderLocation.LocationNumber; } }, { key: "ReferenceNumber", dataType: "string", width: "75px", headerText: "PO or SOor Ref #", unbound: true, formula: function (record, grid) { return "test";// //var references = ""; //if (record.Customer.SalesOrderNumber) { // references = references + "SO: " + record.Customer.SalesOrderNumber + "\r\n"; //} //if (record.Customer.PurchaseOrderNumber) { // references = references + "PO: " + record.Customer.PurchaseOrderNumber + "\r\n"; //} //return references; } }, //{ // key: "ProNumber", dataType: "string", headerText: "Pro Number", // width: "65px", // unbound: true, // formula: function (record, grid) { // return ""; // } //}, { key: "ShipperName", dataType: "string", headerText: "ShipperName", width: "120px", unbound: true, formula: function (record, grid) { return "test";// //return record.OrderLocation.LocationName; } }, { key: "ShipperAddress", dataType: "string", headerText: "ShipperAddress", width: "120px", unbound: true, formula: function (record, grid) { return "test";//return record.OrderLocation.ShippingAddress; } }, { key: "ConsigneeName", dataType: "string", headerText: "ConsigneeName", width: "95px", unbound: true, formula: function (record, grid) { return "test";// return record.Customer.ConsignedTo; } }, { key: "ConsgineeAddress", dataType: "string", headerText: "ConsigneeAddress", width: "120px", unbound: true, formula: function (record, grid) { return "test";//return record.Customer.Address1 + ' ' + record.Customer.Address2 ? record.Customer.Address2 : ""; } }, { key: "ConsigneeCity", dataType: "string", headerText: "ConsigneeCity", width: "85px", unbound: true, formula: function (record, grid) { return "test";//return record.Customer.City; } }, { key: "ConsigneeState", dataType: "string", headerText: "ConsigneeState", width: "65px", unbound: true, formula: function (record, grid) { return "test";// return record.Customer.State; } }, { key: "ConsigneeZip", dataType: "string", headerText: "ConsigneeZip", width: "75px", unbound: true, formula: function (record, grid) { return "test";// return record.Customer.Zip; } } ], autoGenerateColumns: false, dataSource: northwindProducts, responseDataKey: "results", autoCommit: true, height: "400px" }); });
Hello Daniel,
Thank you for your feedback and I'm glad you were able to resolve the issue.
If I can provide you with further assistance, feel free to contact me.
Tsanna
The issue was stemmed from the us setting this value to false:
enableResizeContainerCheck
We've enabled the feature in our base configuration and it is resizing correctly.
thanks!
Hello Karthik,
You can change the path to the js and css files, so that they point to the directory where they are located on your machine or just use the combined script references as in the jsFiddle. If you have any further questions, please let me know.
Regards,Tsanna
Any updates on this?
The demo doesn't work. I think it is referencing local files that aren't included in the zip file.
