1190
using jquery UI Tab inside of IGSplitter causes issues
I am using the jquery UI Tab control inside of the IGSplitter.  I seth HeightStyle to fill on the tab.  This results in the contents of the tab having a 0 height.  If i remove the tab from the IGSplitter then everything works correctly.  Below is a sample
<!DOCTYPE html>
<html style="height: 100%">
<head>
<title></title>
<!-- Ignite UI Required Combined CSS Files -->
<link href="http://cdn-na.infragistics.com/igniteui/2015.2/latest/css/themes/infragistics/infragistics.theme.css" rel="stylesheet" />
<link href="http://cdn-na.infragistics.com/igniteui/2015.2/latest/css/structure/infragistics.css" rel="stylesheet" />
<script src="http://modernizr.com/downloads/modernizr-latest.js"></script>
<script src="http://code.jquery.com/jquery-1.9.1.min.js"></script>
<script src="http://code.jquery.com/ui/1.10.3/jquery-ui.min.js"></script>
<!-- Ignite UI Required Combined JavaScript Files -->
<script src="http://cdn-na.infragistics.com/igniteui/2015.2/latest/js/infragistics.core.js"></script>
<script src="http://cdn-na.infragistics.com/igniteui/2015.2/latest/js/infragistics.lob.js"></script>
<script src="http://cdn-na.infragistics.com/igniteui/2015.2/latest/js/infragistics.dv.js"></script>
<style>
#map {
overflow: hidden;
</style>
</head>
<body style="height: 100%">
<div id="splitter" style="height: 500px">
<div id="tab" style="height: 100%">
<ul>
<li><a href="#treetab">Product Range Browser</a></li>
</ul>
<div id="treetab" style="height: 100%">
<ul id="tree"></ul>
</div>
</div>
<div id="detailSplitter">
<div>
<div id="map"></div>
</div>
<div>
<table id="grid"></table>
</div>
</div>
</div>
<script src="http://www.igniteui.com/data-files/continents-with-countries-and-cities.js" type="text/javascript"></script>
<script>
$(function () {
$("#splitter").igSplitter({
height: "500px",
expanded: function (evt, ui) {
$("#grid_headers").css("width", "100%");
$("#grid").css("width", "100%");
panels: [
{ size: 200, min: 100, max: 250 },
{ collapsible: true }
$("#tab").tabs({ heightStyle: "fill" });
$("#detailSplitter").igSplitter({
orientation: "horizontal",
panels: [
{ size: 500, collapsible: true },
{ size: 200, collapsible: true }
$("#tree").igTree({
dataSource: continentsWithCountriesAndCitiesCoordinates,
dataSourceType: "json",
bindings: {
textKey: "Text",
valueKey: "Text",
childDataProperty: "Countries"
rendered: onTreeRendered,
selectionChanged: onTreeSelectionChanged
function onTreeRendered(evt, ui) {
var unitedStatesNodeElement = ui.owner.nodesByValue("United States");
var unitedStatesNode = ui.owner.nodeFromElement(unitedStatesNodeElement);
initMap();
initCitiesGrid(unitedStatesNode.data.Cities);
ui.owner.expandToNode(unitedStatesNodeElement);
ui.owner.select(unitedStatesNodeElement);
function onTreeSelectionChanged (sender, eventArgs) {
var node = eventArgs.selectedNodes[0];
zoomMapTo(node.data.Latitude, node.data.Longitude, 23);
$("#grid").igGrid("dataSourceObject", node.data.Cities);
$("#grid").igGrid("dataBind");
$("#detailSplitter").igSplitter("expandAt", 1);
function initMap() {
var map = $("#map").igMap({
width: "100%",
height: "100%",
crosshairVisibility: "visible",
overviewPlusDetailPaneVisibility: "visible",
overviewPlusDetailPaneBackgroundImageUri: "http://www.igniteui.com/images/samples/splitter/world.png",
panModifier: "control",
backgroundContent: {
type: "openStreet"
windowResponse: "immediate",
windowRect: {
left: 0.27,
top: 0.20,
height: 0.45,
width: 0.45
return map;
function initCitiesGrid(dataSource) {
var grid = $("#grid").igGrid({
width: "100%",
height: "99%",
dataSource: dataSource,
defaultColumnWidth: "25%",
features: [{
mode: "row",
rowSelectionChanged: function (ui, args) {
var selectedCity = $("#grid").data("igGrid").dataSource.dataView()[args.row.index];
zoomMapTo(selectedCity.Latitude, selectedCity.Longitude, 0.5);
return grid;
function zoomMapTo(latitude, longitude, radius) {
var geographic = geographichFromCentered({
latitude: latitude,
longitude: longitude,
radius: radius
var zoom = $("#map").igMap("zoomToGeographic", geographic);
// Calculates the geographich coordinates of a square around a central point and radius
function geographichFromCentered(centered) {
var geographic = {
left: centered.longitude - centered.radius,
top: centered.latitude - centered.radius,
width: centered.radius * 2,
height: centered.radius * 2
return geographic;
</script>
</body>
</html>
