135
More then 2 Level TreeView
im new to Infragistics Components and now im trying to use the TreeView with Remote Loading. I followed the example http://www.igniteui.com/tree/aspnet-mvc-load-on-demand
Unfortunately, the Methods which are used there to populate the data for the tree are not documentated RepositoryFactory.GetCategoryRepository(IncludeChildren.Products).Get();
RepositoryFactory.GetCategoryRepository().Get();
While im trying to achieve this, I get a bit confused if this use is correct and how to get a 2 level.
I'm trying to build a tree like this:
Documentation 1
-Folder 1
--Folder 1 2
-Folder 2
--Folder 2 2
Documentation 2
-Folder 1
--Folder 1 2
I build a MVC Controler with the following methods:
public ActionResult InfragisticsTree()
            var blManual = new SilverlightApplication.Web.BusinessLogic.Manual();
            var blCategories = new SilverlightApplication.Web.BusinessLogic.Category();
            var dbStat = new SilverlightApplication.Web.DataContainer.DatabaseActionStatus();
            var test = blManual.GetAllManuals(OBCUtilities.ModuleType.Document, false).Select(x => new InfragisticsTreeViewModel
                ID = x.ManualID,
                Name = x.Name,
                Type = "C",
                Items = blCategories.GetCategoriesForManual(x.ManualID, falsefalsefalseout dbStat).Select(c => new InfragisticsTreeViewModel
                    ID = c.CategoryID,
                    Name = c.Name,
                    Type = "C",
                ItemsCount = 1
            return View(test);
[ActionName("tree-data-on-demand")]
        public JsonResult TreeDataOnDemand(string path, string binding, int depth)
            var model = new Infragistics.Web.Mvc.TreeModel();
            var catList = new SilverlightApplication.Web.DataContainer.CategoryList();
            switch (depth)
                case 0:
                    model.DataSource = blCategories.GetCategoriesForManual(Guid.Parse(path.Split(':')[1].Substring(0,36)), falsefalsefalseout dbStat)
                               ID = x.ManualID,
                               Name = x.Name,
                               Type = "C"
                    break;
                default:
                    model.DataSource = blCategories.GetAllCategoriesForCategory(Guid.Parse(path.Split(':')[1].Substring(0, 36)), falsefalsefalseout dbStat)
                                ID = x.ManualID,
                                Name = x.Name,
                                Type = "C"
                    break;
            return model.GetData(path, binding);
My cshtml is same as in the example.
Some questions:
Why do I have to Inlcude the children in the Tree Model when I'm just showing the First Level. A HasChildren property would be enough for showing the expand Arrow on the treeitem?
Why I get a model.GetData Error that its null? How is this expected to work? What should the TreeDataOnDemand return actually?
Kind Regards,
Tim
