430
igGrid is not loaded in Chrome and Firefox browser
Hi All,
I was able to render grid in IE 11 browser successfully.But I tried same grid to load in Chrome and Firefox which was not loaded as expected.I have received some javascript errors which was given below.
Please try to resolve this issue as it was urgent.
'webkitURL' is deprecated. Please use 'URL' instead.
Uncaught SyntaxError: Unexpected end of input
Uncaught Error: No such widget loaded:  igGridColumnMoving
Pradeep SE
  • 17590
    Hello Pradeep,
    In order to find where is the unexpected end of input (as stated in you exception message) I will need to have a look at the code that is throwing this excpotion. Most probably there is a missing closing bracket or something similar. Please try identifying where is the missing statement and if you still need further assistance send me a sample which I can debug on my side and find the root cause for this matter.
     In regards to the second exception I means that the scripts for the ColumnMoving feature are not loaded. For example if you are using igLoader for referencing the scripts the ColumnMoving shpuld be listed or alternatively, if you need more features you all could be added as following:
         $.ig.loader({
             scriptPath: "http://cdn-na.infragistics.com/igniteui/2015.2/latest/js/",
             cssPath: "http://cdn-na.infragistics.com/igniteui/2015.2/latest/css/",
             resources: "igGrid.*
    There is a sample using igLoader at the following link: http://www.igniteui.com/loader/overview
    If you are not using loader please ensure that this particular script is reference either form Infragistics CDN or locally.
    You could try using the combined scripts as well. For example:
     <!-- Ignite UI Required Combined CSS Files -->
        <link href="http://cdn-na.infragistics.com/igniteui/2015.2/latest/css/themes/infragistics/infragistics.theme.css" rel="stylesheet" />
        <link href="http://cdn-na.infragistics.com/igniteui/2015.2/latest/css/structure/infragistics.css" rel="stylesheet" />
        <script src="http://ajax.aspnetcdn.com/ajax/modernizr/modernizr-2.8.3.js"></script>
        <script src="http://code.jquery.com/jquery-1.9.1.min.js"></script>
        <script src="http://code.jquery.com/ui/1.10.3/jquery-ui.min.js"></script>
        <!-- Ignite UI Required Combined JavaScript Files -->
        <script src="http://cdn-na.infragistics.com/igniteui/2015.2/latest/js/infragistics.core.js"></script>
        <script src="http://cdn-na.infragistics.com/igniteui/2015.2/latest/js/infragistics.lob.js"></script>
    I hope you will find my suggestions helpful.
    Please do not hesitate to contact me if you need any further assistance with this matter.
  • 430
    Hi All,
    I have used Infragistics version 2015.Please try to resolve this issue.
    Pradeep SE
