Hi All,
I was developing application using Infragistics version 2015.1 in which I was using trial verison css and js so that when grid was rendering in which feature options are coming in vertically but when I changed to original version css and js then feature options are coming in horizontally and coming outside the grid layout.
Please let me know your suggestions on this. How to fix this issue.
Hello Pradeep,
I’m just following up to see if you’ve been able to resolve your issue.
If you have any questions or concerns or if you need further assistance please let me know.
Best Regards,
Maya Kirova
Infragistics, Inc.
I’ll need some additional information in order to look into your issue.
If possible, could you share a small isolated sample that demonstrates the issue you’ve encountered?
If isolating the issue is not possible could you share the following additional information:
1) The references used on your page to the IgniteUI scripts.
2) The code definition for your igGrid.
3) Exact service release version of the 2015.1 that you’re currently using.
I’m looking forward to your reply.
