2515
igDatePicker exhibiting odd behavior.
I'm trying to migrate some code from 2014.2 to 2015.2. I'm using an igDatePicker. Everything works for 2014.2, but I get odd behavior with 2015.2. I don't know how to get the desired behavior. Whether I set EnableUTCDates to true or false the behavior is wrong.
To test my code I'm pointing to the lastest 2015.2 code.
Here is one scenario:
1. I set the DatePicker value to null.
2. I select date 7/1/2000 in the dropdown and that is what appears in the field for the datepicker. The calendar disappears (as expected).
3. I click the button to show the calendar again and the date is 6/30/2000, one day earlier.
Set dateInputFormat to "dateTime" I get the following result. I start with the date set to null.
1. I select date 7/1/2000. The date that show is 7/1/2000 xx:xx xx, where xx:xx xx is whatever the current time is.
2. I modify the time to be 7/1/2000 00:00 AM.
3. I click the button to display the calendar and the time immediately changes back to xx:xx xx. Not the current time, but the default time that originally appeared in step 1.
4. If I programmatically set the date to 7/1/2000 00:00 AM it shows the previous day when the calendar is displayed.
<script src="http://cdn-na.infragistics.com/igniteui/2015.2/latest/js/infragistics.core.js"></script>
<script src="http://cdn-na.infragistics.com/igniteui/2015.2/latest/js/infragistics.lob.js"></script>
<link href="http://cdn-na.infragistics.com/igniteui/2015.2/latest/css/themes/infragistics/infragistics.theme.css" rel="stylesheet" />
<link href="http://cdn-na.infragistics.com/igniteui/2015.2/latest/css/structure/infragistics.css" rel="stylesheet" />
$("#dte").igDatePicker({
   placeHolder: "Select Date...",
   readOnly: false,
   dateInputFormat: "date",
   enableUTCDates: true,
   focusOnDropDownOpen: true,
   mode: "editable",
   required: true,
   value: null,
   tabIndex: 20,
