If I configure the grid to allow row "delete", then when I am on a PC with a mouse, if I hover over a row I can see the delete icon (the "x"). On mobile devices, however, the delete icon doesn't appear very easily. If I click on the row itself the icon still doesn't appear. On my surface with IE, if I long hold it does appear and then works properly. On an iPad, if I click the row and then move my finger slightly left or right it finally appears and works properly.
How can I easily get the delete icon to appear whenever I select a row on a touch device?
Hi Ryan,
I’ve looked into this and it seems that they renamed the option that checks for pointer events on Edge so it’s:
window.navigator.msPointerEnabled – For IE
window.navigator.pointerEnabled – For Edge
So you can change the if statement as follows:
if(window.navigator.msPointerEnabled || window.navigator.pointerEnabled){
//workaround for IE and Edge on hybrid devices
Unfortunately we don’t have the same testing environment ( Surface + Edge) so I cannot confirm if it’ll work the same way but in theory it should work.
Let me know if you have any issues with the workaround on Edge.
Best Regards,
Maya Kirova
Infragistics, Inc.
Sorry hit send too soon. It sounded to me like you were saying IE and Edge should behave the same on the Surface, but I am not seeing that.
I was using Edge on the Surface. I just tried now with IE on the surface and it worked as you said it would. That seems different than what you are saying it should do though.
Are you testing in on IE, Edge or some other browser?
For other browsers you can remove the if statement as it only applies to browsers that have pointer events ( like IE and MS Edge)
rendered: function(evt){
$("#grid > tbody > tr > td").on("mouseleave", function(evt){
if(window.navigator.msPointerEnabled){
evt.stopPropagation();
Thanks for the response.
Using your sample on my Surface 4, it doesn't behave any differently than before. If I click on a row, I see the "x" button for a bit but then it goes away. If I long hold, the menu comes up, and then if I click somewhere else the menu goes away and the "x" button stays. It's basically the same as it was before. Am I missing something?
