Hello
I have an combobox. it is work fine on 14.2 version with the mode readonly property that is set by javascript at runtime
But after I upgrate to 15.2 version. it is not working
I read on infragistics api help 15.2 and i can't see the set mode for combo at runtime by javascipt. I only see setter at initialize and getter function
How can i set mode by readonly value for igCombo at runtime?
Thanks you very much!
Hello Cuong,
Indeed since v15.2 the combo mode cannot be set at runtime. As a workaround I could suggest you to set attribute "disabled" to the input element that instantiates the combo and cancel dropDownOpening event, so that the combo dropdown to be disabled as well. Attached is a sample for your reference. If you need further assistance, please let me know.
Tsanna
who can help me!
does anyone help me!
