105
Hiding + resizing bug?
Hello!
I am experiencing a small problem when column hiding and resizing are both enabled. Please see the code below and try the following steps:
1. Use the "gear" button on the rightmost column (Age) to access the Column Chooser
2. Hide the column "Age", close the Column Chooser
3. Drag the column "Country" to the left, so that the order of columns is First Name, Country, Last Name
4. Try to resize the Country column - it will not work!
Actually, if you change the background color of the column resizing handle to make it visible, you will notice that the handle disappears from the Country column after the above steps.
Is there a workaround for this? Many thanks!
<!DOCTYPE html>
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
    <title></title>
  <!-- Ignite UI Required Combined CSS Files -->
    <link href="http://cdn-na.infragistics.com/igniteui/2015.2/latest/css/themes/infragistics/infragistics.theme.css" rel="stylesheet" />
    <link href="http://cdn-na.infragistics.com/igniteui/2015.2/latest/css/structure/infragistics.css" rel="stylesheet" />
    <script src="http://modernizr.com/downloads/modernizr-latest.js"></script>
    <script src="http://code.jquery.com/jquery-1.9.1.min.js"></script>
    <script src="http://code.jquery.com/ui/1.10.3/jquery-ui.min.js"></script>
    <!-- Ignite UI Required Combined JavaScript Files -->
    <script src="http://cdn-na.infragistics.com/igniteui/2015.2/latest/js/infragistics.core.js"></script>
    <script src="http://cdn-na.infragistics.com/igniteui/2015.2/latest/js/infragistics.lob.js"></script>
    <style>
  body
   padding-left: 50px;
   padding-right: 50px;
  #gridDiv
   width: 100% !important;
   min-width: 500px !important;
        #grid
   width: 100%;
    </style>
     <script>
      $(function () {
             var height = window.innerHeight;
             $("#grid").igGrid({
                 autoGenerateColumns: false,
                 width: "100%",
                 height: "600px",
                 autofitLastColumn: false,
                 primaryKey: "EmployeeID",
                 dataSource: data,
    columns: [
                    { headerText: "First Name", key: "FirstName", dataType: "string", width: "30%" },
                    { headerText: "Last Name", key: "LastName", dataType: "string", width: "30%" },
     { headerText: "Country", key: "Country", dataType: "string", width: "30%" },
                    { headerText: "Age", key: "Age", dataType: "number", width: "10%" }
                features: [
                         allowDoubleClickToResize: true,
                         columnSettings: [
                           { columnKey: "FirstName", minimumWidth: "10%" },
                           { columnKey: "LastName", minimumWidth: "10%" },
         { columnKey: "Country", minimumWidth: "10%" },
         { columnKey: "Age", minimumWidth: "10%" }
      columnChooserContainment: "window"
    </script>
</head>
<body>
    <div id="gridDiv">
        <table id="grid"></table>
    </div>
    <script>
  var data = [
   "EmployeeID": "56657eab16e7797cc8364561",
   "FirstName": "Kathryn",
   "LastName": "Carney",
   "Country": "Italy",
   "Age": 51
   "EmployeeID": "56657eabad9ad116254c790a",
   "FirstName": "Wilma",
   "LastName": "Stanley",
   "Country": "USA",
   "Age": 20
   "EmployeeID": "56657eab6aa9a9369f056083",
   "FirstName": "Barnes",
   "LastName": "Baldwin",
   "Country": "Italy",
   "Age": 33
   "EmployeeID": "56657eabded05bd38545b61d",
   "FirstName": "Brooke",
   "LastName": "Donaldson",
   "Country": "Italy",
   "Age": 58
 </script>
</body>
</html>
