280
IgUpload Control
I have an IgUpload control which uploads files and dispays them in an IgGrid. The upload control is rendered inside of a modal.
When the files are done uploading the "Done" button is displayed. When the done button selected it does a submit. I am updating my json data source in the background so I do not need to do a submit to update the grid.
Instead of the "Done" button doing a submit would it be possible to just have it close the modal and upload control. I tried attaching an event handler to the button but the handler stays active when the button switched from done to "Upload".
  • 17590
    Hello John,
    In order to ensure that I will provide you with better and more accurate support I will need some additional information regarding your scenario.
    Are you using a custom editor provider with igUpload (as the one used in our online sample)? If this is the case the Done button that you mentioned is the Done button of the editing dialog and you would like to just close the dialog when clicked, is that correct?
    If this is not the case could you please provide me more details and I would be glad to investigate this matter further for you.
    Please feel free to continue sending u[dates to this case at any time.
