Can you help me!
I have an igGrid with 2 column that data type is datetime.
The issuer occurs when i select value from datepicker and then button done is not enable.
Can you help me to solve this problem.
This problem also happends with other type of igGrid that user only select value and user has not entered the value
Thanks you very much!
You're welcome!
i saw
thank you very much!
Hello Cuong,
This issue is already fixed and will be available in the next service release scheduled for March 25, 2016. For updated service release schedule, please see the following Url: http://ko.infragistics.com/support/service-releases.
In the current versions of 15.2 the "Done" button is enabled when exiting the cell by either pressing Tab key or clicking on another cell.
Hope this helps,Martin PavlovInfragistics, Inc.
