20
Dialog editmode enter key closes the dialog in textarea & textarea height
Hello.
I have a grid, inside there is a textfield and a multiline textarea, editmode set to dialog.
Now I want to achieve that when I press the enter key inside the textarea, it has to jump to a new line instead of closing the dialog.
I have tried a couple of workarounds, but none of them working.
I have tried this solution, but the Cancel button not working:
$("#grid").on("iggridupdatingeditrowending", function (evt, ui) {
    var mouseClickButton = evt.originalEvent.target.innerHTML;
    if (mouseClickButton.equals("Done") || mouseClickButton.equals("Cancel")) {
        return true;
    } else if (evt.originalEvent.which = 13) {
        // Focus the cuurent input field
        evt.originalEvent.currentTarget.focus();
    ui.keepEditing = true;
    return false;
My another question is, how can I set the height of the textarea inside the dialog? I have tried a couple of javascript methods to change it's height, but without any luck.
I only want taller textarea inside the editdialog, not in the grid.
Can you help me with that please?
Thank you!
Best regards,
Dominik
  • 2525
    Hello Dominik,
    You can look into the solution provided in this forum thread on how to dispable esc/enter keys from propogating to igGridUpdating:
    http://ko.infragistics.com/community/forums/t/79234.aspx
