i want to use igCombo editor with a multiselect in a grid (version 2015.2) but dataSource is not updated correctly.Main problems: 1) after choosing 2 values, only the first one is written back to dataSource2) editor does not process comma seperated values in initialization-dataSource
I created a jsFiddle with samles:a) click country-column with employeeId 2, select only country USA (deselect UK) => OKb) click country-column with employeeId 2, select countries USA + UK: only UK is selected => NOT OKc) click country-column with employeeId 1, all items should be selected => NOT OKd) add new line and choose countries USA + UK - only USA is visible => NOT OK
http://jsfiddle.net/kdL0Lnx9/7/
Hello md_intact_cc,
This is not supported out of the box.
You can refer to the following topic from our documentation for more details and an example on how to implement a similar scenario by creating a custom editor provider that extends the igCombo:
http://www.igniteui.com/help/working-with-combo-editor-provider#multiSelectionConfig
Best Regards,
Maya Kirova
Infragistics, Inc.
