I am working on a POC and facing issues in getting few things done. I am trying to achieve below objectives:
1) We have to generate client side reports showing data in excel files.
2) These excel report files will be stored at web location and will have formulas, pivot tables, graph, etc.
3) At client side, we will pull data from various resources then fill the data dump in these excel reports.
While trying to achieve this, I am facing couple of issues:
1) How to pass web reference of excel file to "$.ig.excel.Workbook.load" function.
2) I was able to do a data dump on a local excel template. This excel template has two worksheets. First one has a pivot table and other one has data. When I am adding a new worksheet using the JavaScript excel framework, it is corrupting my file. I am getting the following error while opening newly generated file.
"Excel found unreadable content in *******.xlsx. Do you want to recover the contents of this workbook? If you trust the source of this workbook, click yes".
I am not having this issue if excel template file does not have a pivot.
Please suggest.
Following is the error that excel shows while repairing excel file:
-error055360_01.xml
Errors were detected in file 'C:\Downloads\Formulas.xlsx'-Excel completed file level validation and repair. Some parts of this workbook may have been repaired or discarded.-Removed Part: /xl/pivotTables/pivotTable1.xml part with XML error. (PivotTable view) Load error. Line 1, column 0.-Removed Records: Workbook properties from /xl/workbook.xml part (Workbook)
I went through the precise information provided and I gather that you have to generate reports for a client in excel files which will be stored at a web location with formulae, tables etc. You are also facing the “unreadable content” error, which excel seems to be popping up very often now.
After being on many forums and Q & As, I found out that this happens mostly in large sized Excel files or files with complex formulae. Please don’t worry, there are many workarounds to fix this. I am sharing them below:
Workaround 1 : Move the Excel File to a New Folder
Some of the users have reported that they were able to open their Excel file, following the ‘Excel unreadable content’ error, by simply moving the file to a different folder. I hope this works for you as well.
Workaround 2: Install Visual Basic Component
At times, it is found that installing the 'Visual Basic' component of MS Office 2010 resolves error message. To do so, follow these steps:
Reference [https://social.technet.microsoft.com/Forums/Lync/en-US/e5692c4a-924d-44a5-985b-7878f3eb26de/corrupted-excel-file-repair?forum=excel] [https://www.stellarinfo.com/repair-excel-file.php]
I hope this helps you.
Copy "EXCEL12" this file from any working PCs and past it in C;\Windows\ShellNew
If you have any issues regarding Excel file, please visit : http://msofficerecovery.blogspot.com/p/excel-file.html
To recover corrupt or damaged MS Excel file (.xls or .xlsx), I would like to refer Kernel for Excel recovery software. It is designed with an advanced algorithm to recover complete data with full accuracy. To know more about the software, visit: http://www.xlsx.excelfilerepair.org
The issue with the worksheet getting corrupted needs a further investigation by the developers, so I logged it in our internal system. I have also used the duplicate support ticket (CAS-171824) to link to the issue. This way you will receive automatic notifications on the progress.
Regarding your other question:
The .load method itself does not accept a reference to the file but actually needs a data from which to load the workbook. (see http://help.infragistics.com/jQuery/2015.2/ig.excel.Workbook#methods:load)
In the import sample the FileReader API is used to read a local excel file into Uint8Array object, which is then passed to the .load method. In other scenario you may try XmlHttpRequest (server may need to allow CROS for this operation).
Please let me know if you have further questions.
Thank you for the provided sample and detailed information, it is highly appreciated.
The excel library does not support pivot tables and this is pretty likely to be the causing the issue. I am currently working in trying to workaround this behavior and will update you with my findings and on the other questions as well.
