2515
Cannot modify header when also setting height of igGrid
In the rendered event for an igGrid I need to set several css properties for the Header columns. As long as I don't also set the height property when instantiating the igGrid, they css styles are honored. If I set the height at instantiation the css styling for the headers appears to be ignored. I can set the height after instantiating the igGrid, but then I can't use virtualization, which I need. I have also tried using the headerRendered event with the same outcome. Sample code is attached.
igGridHeaderTest.zip
Parents Reply Children
No Data
