990
Uncaught Error: Primary Key
When i set a Primary key on my grid to a column of type number, and then turn on the Updating feature, i get an error when i simply click on a row in the grid like this:
 "infragistics.lob.js:135 Uncaught Error: A record with id 2 could not be found in the data view. Verify the id used for the search and adjust it if necessary."
It is using the row index as the ID instead of the actual column that contains the primary key value that i have set up.
how can i fix this error?
thanks,
wvusaf
  • 15320
    Hello wvusaf,
    Please make sure that you've properly set the primaryKey of the grid. This error is thrown if the primaryKey is not defined. Could you send me an isolated sample or share your code?
    Tsanna
