This is an example I downloaded from Infragistics forum.
I'm seeing this odd behavior in using 2015.2 version of TreeGrid. When I use Infragistics.Web.Mvc version 5.15.2.2081, it gives me a null exception, but when I use Infragistics.Web.Mvc 5.15.1.1005 it works.
I'm pasting the code here because I'm unable to upload my solution files. It is giving me page not found error when I hit save button on upload files dialog. I'm using Chrome.
Views\Home\Index.cshtml
@using Infragistics.Web.Mvc@model IQueryable<WebApplication8.Models.Product>@{ Layout = null;}
<!DOCTYPE html>
<html><head> <meta name="viewport" content="width=device-width" /> <title>Index</title>
<script src="http://modernizr.com/downloads/modernizr-latest.js"></script> <script src="http://code.jquery.com/jquery-1.9.1.min.js"></script> <script src="http://code.jquery.com/ui/1.10.3/jquery-ui.min.js"></script> <script src="http://cdn-na.infragistics.com/igniteui/2015.2/latest/js/infragistics.loader.js"></script>
<!-- Ignite UI Required Combined CSS Files --> <link href="http://cdn-na.infragistics.com/igniteui/2015.2/latest/css/themes/infragistics/infragistics.theme.css" rel="stylesheet" /> <link href="http://cdn-na.infragistics.com/igniteui/2015.2/latest/css/structure/infragistics.css" rel="stylesheet" />
<!-- Ignite UI Required Combined JavaScript Files --> <script src="http://cdn-na.infragistics.com/igniteui/2015.2/latest/js/infragistics.core.js"></script> <script src="http://cdn-na.infragistics.com/igniteui/2015.2/latest/js/infragistics.dv.js"></script> <script src="http://cdn-na.infragistics.com/igniteui/2015.2/latest/js/infragistics.lob.js"></script></head><body> @(Html.Infragistics() .TreeGrid(Model) .ID("grid1") .PrimaryKey("IDProjeto") .ForeignKey("CategoryID") .ForeignKeyRootValue(0) .AutoGenerateColumns(false) .InitialExpandDepth(1) .Columns(col => { col.For(c => c.IDProjeto).HeaderText("ProductID").Hidden(false); col.For(c => c.Name).HeaderText("Name"); col.For(c => c.ReleaseDate).HeaderText("ReleaseDate"); col.For(c => c.CategoryID).HeaderText("Category"); col.For(c => c.ProductNumber).HeaderText("Product Number"); })
.DataBind() .Render())
</body></html>
Models\Product.cs
public class Product
{ public int IDProjeto { get; set; } public string Name { get; set; } public string ProductNumber { get; set; } public DateTime ReleaseDate { get; set; } public string Category { get; set; }
public int CategoryID { get; set; } //public Category Category { get; set; }
Controllers\HomeController.cs
public class HomeController : Controller { // // GET: /Home/
public ActionResult Index() { return View(this.GetProducts().AsQueryable()); }
private List<Product> GetProducts() { List<Product> products = new List<Product>() { new Product() { IDProjeto = 1, Name = "Adjustable Race", ProductNumber = "AR-5381", CategoryID = 0 }, new Product() { IDProjeto = 2, Name = "Bearing Ball", ProductNumber = "BA-8327", CategoryID = 0 }, new Product() { IDProjeto = 3, Name = "BB Ball Bearing", ProductNumber = "BE-2349", CategoryID = 2 }, new Product() { IDProjeto = 4, Name = "Headset Ball Bearings", ProductNumber = "BE-2908", CategoryID = 2 }, new Product() { IDProjeto = 316, Name = "Blade", ProductNumber = "BL-2036", CategoryID = 3}, new Product() { IDProjeto = 317, Name = "LL Crankarm", ProductNumber = "CA-5965", CategoryID = 3 }, new Product() { IDProjeto = 318, Name = "ML Crankarm", ProductNumber = "CA-6738", CategoryID = 3 }, new Product() { IDProjeto = 319, Name = "HL Crankarm", ProductNumber = "CA-7457", CategoryID = 3 }, new Product() { IDProjeto = 320, Name = "Chainring Bolts", ProductNumber = "CB-2903", CategoryID = 2 }, new Product() { IDProjeto = 321, Name = "Chainring Nut", ProductNumber = "CN-6137", CategoryID = 2 } };
return products; }
public void SaveData() { GridModel model = new GridModel(); List<Transaction<Product>> products = model.LoadTransactions<Product>(Request.Form["ig_transactions"]); } }
Hello C R ,
Based on the code snippets what seems to be missing is the setting for the ChildDataKey option.
The ChildDataKey should be set to the name of a property in the model of type Queryable ( this property will then be populated to create a hierarchical structure).
So for example the model can look like this:
public List<Category> Categories { get; set; }
And the ChildDataKey can be set to “Categories”.
Let me know if setting the option solves your issue.
Best Regards,
Maya Kirova
Infragistics, Inc.
