110
Custom Row Edit Dialog with igGrid and igCombo in dialog
I'm using the Custom Row Edit Dialog to modify values in a iggrid. In the dialog, I want to render an igCombo and igGrid. Neither of these are used to directly edit values in the grid. The user will select something from the igCombo, which will populate a list in the dialog's igGrid. Then the user will select a row in the dialog's igGrid. Upon selection, the StartDate and EndDate input fields in the dialog will be updated. Clicking Done will update the StartDate and EndDate in the row being updated.
My question is, how do I put an igCombo and igGrid in the dialog. I'm using MVC and building a partial view for the contents of the dialog.
I followed the example in the documentation with the script tag. However, the igCombo and igGrid will not render in the dialog.
<script id="dialogTemplate" type="text/html">
If I change the script table to be a div, as follows, the igCombo and igGrid render twice in the dialog.
<div id="dialogTemplate" >
Since neither the igCombo nor igGrid are directly related to the fields in the grid row I'm updating, I cannot specify editors in the .ColumnSettings.
