100
igGrid header rendered twice
Because it is not possible to set the datasource of igGrid to Javascript-Variable with MVC helper (see other Post here), I tried a workaround: In rendered-Event I set datasource to Javascript variable containing Json data array. Seems to function as expected, until I set height of igGrid to absolute px on initialization. Now grid header is rendered twice. Is's a bug for sure. Occurs only if iggrid colum definitions are specified, grid height is set (grid initialization) and datasource is set in render-Event.
Example (freely adapted from Infragistics example "Grid JSON Binding") http://jsfiddle.net/p86zf5fc/4/
Infragistics IgniteUI 2016.1 (16.1.20161.1009)
