After I have selected an item from the drop down list, I position the cursor in the middle of the text box and then remove a character, the cursor pops out to the end of the line. This is very annoying when trying to edit a custom value. Is there any way to override this behavior? I would like to keep the cursor where I placed it. Here is the combobox options I am using:
@(Html.Infragistics().ComboFor(item => item.CustomerID).ID("customerCombo").Virtualization(true).AutoComplete(false).AllowCustomValue(true).AutoSelectFirstMatch(false).FilteringType(ComboFilteringType.Local).FilteringCondition(ComboFilteringCondition.Contains).Width("100%").Height("36px").ValueKey("CustomerID").TextKey("CustName").CompactData(false).ItemTemplate( "<div style='height:40px'><div><b>${CustName}</b></div>" + "<div style='border-bottom: thin solid black;'><span class='vd-combo-item-label'>Account:</span>${CustAcct}</div>").ClientEvents(new Dictionary<string, string>() { { "rendered", "function(evt, ui) {ui.element.find('.ui-igcombo-button').prop('title', '');}" } }).Render())
My apologies, I found that this release was not installed fully. This release does resolve the problem.
I have tested this and have been unable to reproduce this in the latest service release. Note that our website does not run of the latest service release so it would still show there. What are the exact steps you are using to reproduce this behavior?
I have that release installed and the problem is still occurring. Still seems to be doing it on your web site as well.
Yes the fix is in June Service Release.
The latest service release I see is 20152.2235 released 6/27/2015. Is this fix contained in this release?
