Hi - I am using Ignite UI 2015.2 version. How to make cell read only/editable based on user role. I am using editRowStarting event, But not able to get user role information in this method.
Ravi Kumar
Hello Ravi Kumar,
If you want some cells from a column to read only and some not, storing info for this in each record is great approach. Probably the most performant.
But if you want all the cells from a column to be read only, then you can use columnSettings - http://www.igniteui.com/help/api/2016.1/ui.iggridupdating#options:columnSettings.readOnly
Thanks for your quick response. I already implemented logic by storing user role in each row. I am looking for optimal solution with out storing user information in the grid.
Based on the rowID from editRowStarting you can find the record by key - http://www.igniteui.com/help/api/2016.1/ui.iggrid#methods:findRecordByKey.
And if the user role information is stored in each record, you would be able to reach it.
