190
oData - orderBy child collection
If my oData includes a child (in this case state), and I want to be able to group by the state name.   Unfortunately with the code I presently have below, when grouping by state, it passes $orderby=state+asc,  this causes an error.   I would need it to pass $orderby=state/name+asc.   Is there a way to code the grid to do this?
oData & grid code below:
"odata.metadata": "http://localhost:63609/odata/$metadata#EscheatmentsOData",
"odata.count": "1",
"value": [
"state": {
"id": 1,
"abbreviation": "AL",
"escheatmentname": "STATE OF ALABAMA",
"name": "Alabama",
"territory": false,
"updateUser": "SeedData",
"updateTime": "2016-05-18T15:44:03.103"
"status": {
"id": 1,
"name": "NEW",
"description": "Auto-assign when property record first shows up in the R07306",
"updateTime": "2016-05-18T15:44:09.583"
"address": {
"id": 1,
"firstName": "FirstNameVal",
"middleName": "MiddleNameVal",
"lastName": "LastNameVal",
"streetAddress1": "Street1Val",
"streetAddress2": "Street2val",
"streetAddress3": "street3val",
"city": "cityval",
"zip": "zipval",
"updateUser": "corp\\test",
"updateTime": "2016-05-25T00:00:00"
"comments": [],
"id": 1,
"year": 2016,
"cycleStartDate": "2016-01-01T00:00:00",
"cycleEndDate": "2016-12-31T00:00:00",
"accountNumber": "123456",
"accountValue": 100,
"taxId": "123456789",
"birthDate": "1920-06-20T00:00:00",
"dealerBranch": "DealerBranchValue",
"planType": "PlanTypeValue",
"socialCode": "SocialCodeValue",
"deathDate": null,
"desceased": false,
"fiduciary": false,
"regLine1": "ReqLine1Value",
"regLine2": "ReqLine2Value",
"regLine3": "ReqLine3Value",
"regLine4": "ReaLine4Value",
"regLine5": "ReqLine5Value",
"regLine6": "ReqLine6Val",
"build": "BuildVal",
"checkNumber": "CheckNumberVal",
"dollarAmount": 100,
"shareAmount": 200,
"eligibleDate": "2016-06-20T00:00:00",
"establishedDate": "2016-01-05T00:00:00",
"fundNumber": "FundNumberVal",
"lastContactDate": "2016-05-25T00:00:00",
"originalRunDate": "2016-05-25T00:00:00",
"lastRunDate": "2016-05-25T00:00:00",
"late": true,
"yearsLate": 5,
"ddLetterDate": "2016-05-01T00:00:00",
"propertyType": "1",
"rpoDate": "2016-01-01T00:00:00",
"checkDate": "2016-01-02T00:00:00",
"stateCutOffDate": "2016-01-03T00:00:00",
"stateDormancy": 0,
"stateDueDate": "2016-12-15T00:00:00",
"forceIndicator": false,
Grid:
///*----------------- Instantiation -------------------------*/
$("#grid").igGrid({
    virtualization: false,
     dataSource: "/odata/EscheatmentsOData?$expand=state,status,address",
     primaryKey: "id",
        restSettings: {
                update: { url: "/api/Escheatmentsapi/" },
                remove: { url: "/api/Escheatmentsapi/" },
                create: { url: "/api/Escheatmentsapi/" }
    autoGenerateColumns: false,
    autoGenerateLayouts: false,
    localSchemaTransform: true,
    responseDataKey: "value",
    renderCheckboxes: true,
    columns: [
            headerText: "Id", key: "id", dataType: "number"
            headerText: "State", key: "state", dataType: "object", formatter: function (val) { return val.name; }
            headerText: "Year", key: "year", dataType: "number"
             headerText: "Fund", key: "fundNumber", dataType: "number"
            headerText: "Account No", key: "accountNumber", dataType: "string"
            headerText: "Tax Id", key: "taxId", dataType: "string"
            headerText: "Check No", key: "checkNumber", dataType: "number"
            headerText: "Description", key: "planType", dataType: "string"
            headerText: "Status", key: "status", dataType: "object", formatter: function (val) { return val.name; }
            headerText: "Value", key: "dollarAmount", dataType: "string"
    width: "100%",
    features: [
            type: "remote",
            pageSize: 10,
            recordCountKey: "odata.count"
            columnSettings: [
                columnKey: "year",
                isGroupBy: true,
                dir: "asc"
  • 29417
    Verified Answer
    Hello Brian,
     By default there’s no  option in the grid that can re-define the generated url params.
    You could however use the urlParamsEncoded setting on the igDataSource:
    http://www.igniteui.com/help/api/2016.1/ig.datasource#options:settings.urlParamsEncoded
     And in it change the sortingParams’s $orderby value when a column is grouped.
    For example:
    var myUrlParamsEncoded = function (item, params) {
                    params.sortingParams.$orderby = "CustomName asc";
    Which would let you change the orderBy query string before the request is send to the server.
    Let me know if that would solve your issue.
    Best Regards,
    Maya Kirova
    Infragistics, Inc.
