Hi there,
I have 2 questions regarding legends that I cannot seem to find the answer for anywhere else:
1) Is there a way to get the values to show up for each item in the legend? I would need to do this for different types of charts, including column, pie, and scatter.
2) I have an igDataChart consisting of one series with 10 data points. When I enable the legend, it only shows a single item representing the entire series. Is there a way to get the legend to show an item for each data point in the series? I would also need to show the values for each data point, as per the previous question.
I appreciate your assistance.
Thanks.
Hi Corey,
1) A possible approach is to format the series label, which is therefore used by the legend, as shown in this sample:
http://www.igniteui.com/doughnut-chart/configure-legend
2) This cannot happen out of the box, so you can iterate through the legend span items (As shown in the example from 1) ) and write values that are read from the series data source.
Please let us kow if you face any issues during implementation, I will be glad to help
