25
Bind data to combobox from model
I have a set of objects in model. I created a combofor control and assigned string property for both ValueKey and TextKey(find an example below). When I am setting a selected value to the model property, it is not displaying anything in the control. But it is working fine, if I am setting ValueKey as integer type. Could you please suggest us some options to achieve this by setting ValueKey and TextKey as string.
<%= Html.Infragistics()
.ComboFor(m => m.ProgramName)
.ID("cmbProgram")
.ValueKey("ProgramName")
.TextKey("ProgramName")
.ItemTemplate("${ProgramName}")
.DataBind()
.Render() %></td>
  • 11095
    Hello Hemalatha,
    ComboFor is used for a model with property that can have different values. In other words if you have the following class with the following properties
    public class User
        public int Id { get; set; }
        public string Username { get; set; }
        public string CountryId { get; set; }
    The ComboFor wrapper can be used to set a Combo for changing the CountryId value (note that country id is not integer but string).
    In order to have values in the dropdown list a collection of countries should be provided to the combo.
    I have created a small sample to demonstrate that.
    Let me know if you need further assistance.
    ComboSample.zip
