105
ig grid reference errors & injecting ig grid to the DOM
Hi ,
I am developing a SPA application using JavaScript and I am facing issues binding data to a ig grid.
 Please help me with the following . I am attaching a sample project
1)      On index.html I had to comment infragistics.datasource.knockoutjs.js and infragistics.ui.grid.knockout-extensions.js . when I uncomment those files I get an error on IE11 like
“Unhandled exception at line 1, column 1 in http://localhost:52306/js/extensions/infragistics.datasource.knockoutjs.js
 0x800a1391 - JavaScript runtime error: 'define' is undefined”
 IE11 is our default browser and we need the ig grid to be working on IE11.
 2)      On Search results page which is the loaded as the default .
I have defined a template and a js-hook to display results
var template = '\n\t\t<section class="search" js-hook="search">\n\t\t\t<h1><span js-hook="total"></span>' +
                       'Search Results for ‘<span js-hook="term"></span>’\n\t\t</section>\n\t\t'+
                    '<section class="results" js-hook="results">\n\t\t\t'+
                    '<header>\n\t\t\t\t<div class="category bpid-header"><img src="/assets/updown.svg" /><span>BPID</span></div>\n\t\t\t\t' +
                    '<div class="category name-header"><img src="/assets/updown.svg" /><span>Name</span></div>\n\t\t\t\t' +
                    '<div class="category status-header"><img src="/assets/updown.svg" /><span>Status</span></div>\n\t\t\t\t' +
                    '<div class="category date-header"><img src="/assets/updown.svg" /><span>In-Service Date</span></div>\n\t\t\t</header>\n\t\t\t' +
                    '<div class="results-list" js-hook="results-list">\n\t\t\t</div>\n\n\t\t\t' +
                    '<div class="pagination">\n\t\t\t\t<img class="arrow-left" src="/assets/down_grey.svg" />\n\t\t\t\t' +
                    '<div class="page">1</div>\n\t\t\t\t<div class="page selected">2</div>\n\t\t\t\t<div class="page">3</div>\n\t\t\t\t' +
                    '<div class="page">...</div>\n\t\t\t\t<div class="page">10</div>\n\t\t\t\t '+
                    '<img class="arrow-right" src="/assets/down_grey.svg" />\n\t\t\t</div>\n\t\t</section>\n\t\t\t\t' +
             '<div class="results-ig-list" js-hook="results-ig-list">\n\t\t\t</div>\n\n\t\t\t'   ;
 3)      I also defined  JSON data to bind
var jsonSearchResults = JSON.parse("[{\"LOOKUPID\":1043700.0,\"EPMBPID\":\"A13007135\",\"EPMBPIDNAME\":\"A13007135    CARRIZO SPRINGS REGULATOR REPL\",\"PCPLMPPROJECTSTATUSID\":\"Constr b\/w Gates 4-5\",\"P6PROJECTEDINSERVICEDATE\":\"2014-06-30T00:00:00\"}]");
When I bind this JSON Data to a div results-list like
$("[js-hook='searchresults-element'] [js-hook='results-list']").html(results);
I am able to display the results.
Below the div results-list I am trying to display the same data on div results-ig-list  where I am trying to inject a iggrid
 Basically I want to use ig grid to display data
I have declared a grid
      var grid = '<table id="gridMain_1" style="font-size:10px" data-bind="igGrid: { '+
                    'height: "100%", '+
                 'width: "100%", '+
                 'dataSource: data, '+
                 'primaryKey: "LOOKUPID",'+
                 'autoGenerateColumns: false, '+
                  'virtualization: true, '+
                  'virtualizationMode:"continuous", '+
                  'enableAddNewRow: false, '+
                  'columns: [ '+
                 '{ key: "LOOKUPID", dataType: "number", hidden: true,headerText: "Look Up Id"}, ' +
                 '{ key: "EPMBPID", dataType: "string", headerText: "BP ID" }, '+
                 '{ key: "EPMBPIDNAME", dataType: "string", headerText: "Project Name"}, '+
                 '{ key: "PCPLMPPROJECTSTATUSID", dataType: "string", headerText: "Status" }, '+
                 '{ key: "P6PROJECTEDINSERVICEDATE", dataType: "string", headerText: "In Service Date" }, '+
                 'features: [ '+
                 '{name:"Paging",' +
                 'type:"local", '+
                 'pageSize:10 '+
                 '{name: "Resizing"}, '+
                 '{name: "Updating", '+
                 'enableAddRow: false, '+
                 'enableDeleteRow: false, '+
                 'showDoneCancelButtons: false, '+
                 'editRowStarting: function(evt, ui) { return false } } ] }"></table>';
Then I try to inject the grid
$("[js-hook='searchresults-element'] [js-hook='results-ig-list']").html(grid);
But nothing appears . Also how do I bind data to this injected grid ?
           self.data(jsonSearchResults);
           $('#gridMain_1').igGridPaging('pageIndex', 0)
Self.data(jsonSearchResults) returns a error
My questions?
1)  Why am i getting those reference
2) How do I inject the grid to my DOM?
3)  How do I bind data? Can you show me in the example above?
I have attached my sample project.
IgGridSite.zip
