IgGrid seem not support paging in angular context. I have a angular service to load data by paging. I will call method in this service to bind data to igGrid.
I've setup grid enable paging features:
$scope.gridOptions = { dataSource: dataSource, width: "100%", height: "400px", primaryKey: "id", autoCommit: true, autoGenerateColumns: false, autoAdjustHeight: true, columns: columnsTranslated, features: [{ name: "Paging", type: "local", pageSize: pageSize, showPageSizeDropDown: false }] }
And dataSource= angularService.getData(pageindex,pageSize);
But I don't know how I can specify total number of record/total for this case.
I don't want grid bind directly to data source by an URL because I want to pre-process data in angularService before it is received on client.
You need to specify the type of the data source and response data key:
I modified your sample a bit:
http://jsfiddle.net/qfabkd58/7/
It not work as expected.
I upload my sample code to here:
http://jsfiddle.net/quyetvv/qfabkd58/
When run this, I can see my dataSource and totalCount is correct as I expected but it is not working.
Here is error log:
http://screencast.com/t/awHuhhEZDE
Could you please help send me a working example from this code?
Thank you so much!
You can have
datasource = [{records:{id: 1, name: "acb"},{id: 2, name: "acb2"},{id: 3, name: "acb3"}, totalCount: 3}]
And please note that you may also need to specify the responseDataKey option to be "records".
As understand datasource = angularService.getData(pageindex,pageSize); must return an arrays with field to bind into grid
Eg:
datasource = [{id: 1, name: "acb"},{id: 2, name: "acb2"},{id: 3, name: "acb3"}]
If I set recordCountKey: "totalCount", how I put totalCount value in datasource?
Your dataSource should have a property field (if it doesn't already has such) which contains information about the total records count and this property should be passed to igGridPaging with the recordCountKey option.
