230
Filter summary not updating when filter is cleared
There seems to be a bug with filter summary when one of the filters is cleared by clicking "Clear Filter" in the filter options.
It is also reproducible in your online example: http://www.igniteui.com/grid/simple-filtering.
To reproduce:
Try filter using:
First Name : "j", Country : "USA".
You will see that it showed "12 matching records" in the filter summary.
Try clearing only the country filter:
It still showed "12 matching records" in the filter summary when in fact it should be 25.
Is there an "easy" workaround available or setting I need to set to enable it to update the filter summary correctly?
Charles
p.s.:a workaround I found is to get the containing summary element and modify the text directly on dataFiltered event.
