100
After expanding hierarchical grid, child grid row selection not returning row data.
i used below link to manually expand and collapse hierarchical grid rows.
https://ko.infragistics.com/community/forums/f/ignite-ui-for-javascript/tags/igHierarchicalGrid
after expand has done i am trying to select element from child grid as follow :
var childGrids = $(this.element).igHierarchicalGrid("allChildren");
$.each(childGrids, function (ix, grid) {
selRows = $(grid).igGridSelection("selectedRows");
//selRows = $(grid).igGrid("selectedRows");
it returns empty array. due to which i am not able to set value to any cell as well.
var rows = $(grid).igGridSelection("selectedRows");
$.each(rows, function (ix, row) {
// getting the child grid selected row cell data
var rowId = row.element.data("id");
var cellValue = $(grid).igGrid("getCellValue", rowId, "Mycol");
  • 29417
    Hello Rupali ,
    If you’re aiming to find the rows that were selected  in one of the child grids, then I suggest you check if the current child grid you’re looping through has selected rows and if does break the loop, for example:
    var selRows;
    if(selRows.length > 0){
    //breaks loop
    return false;
    Since the HierarchicalGrid does not allow different children to have selected rows only a single child grid can ever has selected rows at a time.
    Let me know if you have any questions .
    Best Regards,
    Maya Kirova
    Infragistics, Inc.
