Hello everyone,
I am using ignite-ui version 15.2.20152.1027 in my web application. I am using the igGrid with the cell editing features enabled. Here is my problem:
When I click in the cell, it enters edit mode as it should. Then when I type one character, it immediately moves the cursor to the end of the text. I have to manually move my cursor back to the desired position and type another character. Then after I type that character, the cursor moves back to the end of the text again.
I found one other post regarding this issue here, but the original poster never shared his solution.
How can I correct this behavior?
Hello jouin,
I am glad that my suggestion was helpful for you.
This seems to have fixed the problem. Thank you very much for your help.
This issue is resolved in the latest service release available for version 15.2, which currently is 2235. My advice is to get this version from our web site https://ko.infragistics.com by following these steps:
1) Go to our web site www.infragistics.com and log with your account.
2) Click Support/Account in the top right corner of the page.
3) Select View Account Info from the menu.
4) This will lead you to My Keys&Downloads section. Select your product from the list
Under the Service Releases tab you will find the latest service release available for download.
Please let me know if you have any additional questions regarding this matter.
