I'm trying to use a scatter serie for a chart that needs to display on X Axes a datetime and for Y a quantity (double)
I've defined my chart as
<script type="text/javascript"> function createScatterChart(selector, seriesType, dataSource) { $(selector).igDataChart({ width: "100%", height: "500px", title: "Test", dataSource: dataSource, axes: [ { name: "xAxis", type: "numericX", label: "Label", formatLabel: function (val) { var bVal = new Date(1000 * val); return bVal; } } ], series: [ { name: "series1", title: "Test Series", type: "scatter", xAxis: "xAxis", yAxis: "yAxis", showTooltip: true, xMemberPath: "hour", yMemberPath: "qta" } ], horizontalZoomable: true, verticalZoomable: true, windowResponse: "immediate" }); } $.ajax({ url: '@Url.Action("LoadChart", "IntraDayChart")', dataType: "json", type: "GET", contentType: 'application/json; charset=utf-8', success: function (data) { createScatterChart("#chartScatter", "scatter", data); }, error: function (xhr) { alert('error'); } });</script> while the datasource is composed of a list<IntraDayChartItem> where a IntraDayChartItem is <pre> public class IntraDayChartItem { [Alias("ORA")] public DateTime hour { get; set; } [Ignore] public string HourString => hour.ToString("HH:mm:ss.fff"); [Alias("PREZZO")] public double? price { get; set; } [Alias("QTA")] public double? qta { get; set; } [Alias("PREZZO_ORDINE")] public double? priceOrder { get; set; } [Ignore] public double? priceOrderPlus => sign == 0 ? priceOrder : null; [Ignore] public double? priceOrderLess => sign == 1 ? priceOrder : null; [Alias("QTA_ORDINE")] public double? qtaOrder { get; set; } [Alias("SEGNO")] public int? sign { get; set; } [Ignore] public long HourInt { get { return hour.Ticks; } } }
<pre>
How can I've the X axes containing datetime and possibily auto scaled?
I have the same issue and I want to show date as xAxis for scatter chart.
Did you solve your problem?
Any idea?
Generally in order to have the x axis contains real date time object you will need to have your x axis be of type categoryDateTimeX. However the scatter series do not support this type of axis, so you should keep the approach I see in your code, i.e formatting the label to receive date. More information on configuring the axis and series can be found at http://www.igniteui.com/help/igdatachart-series-requirements
Please let me know if you have further questions on the matter, I will be glad to help.
