1010
igNumericEditor is not accepting more than 2 decimals in igGrid column
Hi Support,
I created an igGrid with 1 row. Inside I have defined two columns for prices, and the columns I've tried to set the options for the numeric editor. I've set the minDecimals and maxDecimals to 4 and 5, respectively. I've also defined the formatting on the columns as "##0.0000".
However, if I try to place a number, say 1.0125, it displays the price as 1.0100. I am not sure what other setting I need to place. Also, I've tried adding buttonType: "spin" and spinDelta: 0.005, but no spinner shows up in the cell on edit.
I am not sure how to proceed. I've placed the javascript defining the grid below:
$("#bidasktable").igGrid({
    width: "100%",
    autoAdjustHeight: true,
    autoGenerateColumns: false,
    autoCommit: true,
    caption: "Bid/Ask",
    renderCheckboxes: true,
    primaryKey: "Key",
    columns: [
        { headerText: "Key", key: "Key", width: "0%", dataType: "number", hidden: true },
        { headerText: "IOI", key: "IsBidIOI", width: "15%", dataType: "bool" },
        { headerText: "Qty", key: "BidQuantity", width: "15%", dataType: "number", format: "int" },
        { headerText: "Bid", key: "BidPrice", width: "20%", dataType: "number", format: "##0.0000" },
        { headerText: "Ask", key: "AskPrice", width: "20%", dataType: "number", format: "##0.0000" },
        { headerText: "Qty", key: "AskQuantity", width: "15%", dataType: "number", format: "int" },
        { headerText: "IOI", key: "IsAskIOI", width: "15%", dataType: "bool" },
    features: [
            mode: "row",
            multipleSelection: false
            allowDoubleClickToResize: true,
            deferredResizing: false
            enableAddRow: false,
            enableDeleteRow: false,
            editMode: "cell",
            horizontalMoveOnEnter: true,
            columnSettings: [
                { columnKey: "IsBidIOI", editorType: "checkbox" },
                    columnKey: "BidQuantity",
                    editorType: "numeric",
                    editorOptions: [
                        { dataMode: "int" }
                    columnKey: "BidPrice",
                    editorOptions: [
                              dataMode: "double",
                              minDecimals: 4,
                              maxDecimals: 5
                    columnKey: "AskPrice",
                    editorOptions: [
                              dataMode: "double",
                              minDecimals: 4,
                              maxDecimals: 5
                    columnKey: "AskQuantity",
                    editorOptions: [
                        { dataMode: "int" }
                { columnKey: "IsAskIOI", editorType: "checkbox" },
Can you please advise?
Thanks!
  • 15320
    Verified Answer
    Hello C R,
    I looked at your code and noticed that you've defined editorOptions as an array, however it's an object, so you should remove the "[ ]" braces and the editorOptions object should look like this:
    editorOptions:
             dataMode: "double",
             minDecimals: 4,
             maxDecimals: 5
    Please let me know if you have further questions.
    Tsanna
