I'm using the igGrid of IgniteUI 2016.1 and I'm searching for an easy way to swap/move the current (selected) row programmatically (JavaScript) one row up (or also down). Is there an easier way as to "swap" the data of each column (excepting the value of the key column)? Column moving will be supported but rows...
Hello Martin,
Thanks for this tip. I will check it.
You can checkout this forum thread: http://ko.infragistics.com/community/forums/t/90630.aspx. There is a sample attached which does row swapping.
Best regards,Martin PavlovInfragistics, Inc.
