I'm currently working with infragistic grid and I need to change the timeout of infragistic grid due to the time of getting all data.
GRID:
@(Html.Infragistics()
.Grid<Model>()
.ID("pcd-grid")
.AutoGenerateColumns(false)
.RenderCheckboxes(true)
.PrimaryKey("ID")
.EnableUTCDates(false)
.Columns(column =>
... Here I need to specify timeout
HERE THE ERROR:
{,…}Metadata: {timezoneOffset: 7200000,…}Records: [{...,…},…]TotalRecordsCount: 0
Thank you for your help
Hello cem ozbas,
The grid has no settings to specify the timeout, which is why I suggested using ajaxSetup to define a global level timeout. You can see an example of how this affects the igGrid's timeout in the sample I have attached with this post.
In the sample, I have set the global $.ajax timeout to be 5 seconds. After 5 seconds, the grid's requestError event will fire and display an alert.
After looking into setting a specific timeout value for the igGrid and doing some research, specific timeouts for the grid have been determined to be a new product idea. You can suggest new product ideas for future versions (or vote for existing ones) at http://ideas.infragistics.com.
There are many benefits to submitting a product idea:
- Direct communication with our product management team regarding your product idea.- Notifications whenever new information regarding your idea becomes available.- Ability to vote on your favorite product ideas to let us know which ones are the most important to you. You will have ten votes for this and can change which ideas you are voting for at any time.- Allow you to shape the future of our products by requesting new controls and products altogether.- You and other developers can discuss existing product ideas with members of our Product Management team.
Steps to create your idea:
1. Log into the Infragistics Product Idea site at http://ideas.infragistics.com (creating a new login if needed).2. Navigate to the product / platform channel of your choice (e.g. WPF, Windows Forms, ASP.NET, HTML5 / Ignite UI, iOS / NucliOS, etc.)3. Add your product idea and be sure to be specific and provide as much detail as possible. • Explain the context in which a feature would be used, why it is needed, why it can’t be accomplished today, and who would benefit from it. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it. Be convincing! • Include a link to this thread in your idea so product management will be able to look back at this case.
The Product Idea site puts you in the driver’s seat and allows you to track the progress of your ideas at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
Thank you for contacting Infragistics.
Hi Michael,
I hoped that would be as easy but I'm not using any jquery options. I'm using Infragistic mvc helper (as I mentioned in my example) who execute the queries and doing all stuff on its own. It should have any option to define the ajax timeout.
What you say jquery is used my infragistic grid. Please read questions more careful and give a clear answer rather than a simple link, I'm not beginner on jquery ajax stuff. We are actually blocked with this issue and still losing time
Thank you
Thank you for posting in our forums!
You can specify a default timeout length using jQuery's ajaxSetup() method.
If you have any further questions or concerns with this, please let me know.
