Have very simple setting :
<body> <div id="auditSetCombo"></div> <script type="text/javascript"> var uoaAuditSetUpController = function () { function bindAuditSetCombo() { var auditsDDwn = JSON.parse('[{"AuditId":0,"AuditName":"unassigned"},{"AuditId":1,"AuditName":"Audit_32513_1"},{"AuditId":2,"AuditName":"Audit_32513_2"},{"AuditId":3,"AuditName":"Audit_32513_3"}]'); $('#auditSetCombo').igCombo('option', 'dataSourceType', 'json'); $('#auditSetCombo').igCombo('option', 'dataSource', auditsDDwn); $('#auditSetCombo').igCombo('dataBind'); }
return { bindAuditSetCombo: bindAuditSetCombo }; }(); $(function () { $("#auditSetCombo").igCombo({ valueKey: "AuditId", textKey: "AuditName" }); uoaAuditSetUpController.bindAuditSetCombo(); }); </script>
</body>
when run getting the following error :
Uncaught Error: There was an error parsing the JSON data and applying the defined data schema: Cannot read property 'Metadata' of null infragistics.core.js:228
I am on 14.1 and if I would remove $('#auditSetCombo').igCombo('option', 'dataSourceType', 'json'); it would work fine... why it is not accepting 'json' type.. it works in similar circumstances in other places..
That was not very helpful as the version used in the project needed to be preserved..
Hello mcseidel,
Thank you for posting in our community!
I would like to inform you that igCombo was improved and rewritten in version 14.2 . This means that all other older versions are considered non-supported.
I'm sending you sample with your configurations but with the latest combo version. As you can see there - no error is thrown.
Also our IgniteUI product is already open source and the latest version of the source code (of almost all of the widgets) can be found here: https://github.com/IgniteUI/ignite-ui .
