My igGrid groupby specific column along with the RowSelectors missing checkboxes during initialization of the Grid, this is happening only for the fist time loading the grid ,after that if i refresh the grid checkboxes are appearing.I am using remote grouping. Please assist me this issue.
Thanks & Regards
Nagaraju P
Hello Nagaraju,
Thank you for the update that sample is working fine with the latest version 16.1 and able to reproduce with version 15.1.
Please note that volume 15.1 is out of the maintenance and has already had its last service release so if the resolution of this development issue requires a change to the assemblies it will be necessary to upgrade to a more recent volume of Infragistics for igniteUI.
You can see our product lifecycle here: <http://ko.infragistics.com/support/product-lifecycle>
Please let me know if I can provide any further assistance
Thanks for the replay.
I am using IG version(15.1) and able to recreate the issue ,I am sharing the java script files that i have used to recreate the issue.
Can i know how to fix this issue using the same version?
Thank you for providing sample application.
As you are using loader in your application and you did not provide the version of the control or the JS file you are using I modified the sample with latest build (16.1).
I run the sample and not able to reproduce the same behavior you are describing.When page load grid initializes and does render the checkbox.
I have attached the modified sample project I used to test this. Please test this project on your PC; whether or not it works correctly may help indicate the nature of this problem.
If the project does show the product feature working correctly, this indicates a possible problem is in the version or js files .
Please let me know if I can provide any further assistance.
