215
I CAN'T UPDATE DATA OF IG.GRID
hellow
i have one igGrid table, with datasource is in a server
my Grid show the data all right, but;
1.- i can't update valors in a server,
2.- when i press add row.. nothing
3.- when i click in a row, this row change her state to, editing, is ok, but in the 3º colum, the URL, i want listbox no textbox
I do not want to write and edit in the 3rd column only in the third column, I would like to appear a listbox with values from another table, eg value = column1, Name = "column2"
that only can select the various URL's in the database, and keep the value, then using the value field, to save the ID so the URL i not the text itself
can help me please?
my code is:
CONTROLER:
<textarea cols="70" rows="10" readonly style="background-color:transparent; font-weight:bold; border:none">
using System;
using System.Collections.Generic;
using System.Linq;
using System.Web;
using System.Web.Mvc;
using ECOMMERCE_API.Code;
using ECOMMERCE_API.Models;
using ECOMMERCE_API.Funciones;
namespace ECOMMERCE_API.Controllers
public class AdminController : Controller
public List<SQLDateModel> Data { get; set; }
public List<ProcessingData> Tablas { get; set; }
// GET: Admin
public ActionResult Index()
if (AdminModel.IsLogged == false) { return RedirectToAction("LoginAdmin", "Home"); }
var NewVista = new ProcessingData();
NewVista.CreateTablaUsers();
return View();
</textarea>
MODEL:
</textarea>
AND THE WEB CODE IS:
LAYOUT:
using System;
namespace ECOMMERCE_API.Models
public class AdminModel
//Datos de acceso
public static string User { get; set; }
public static string Pass { get; set; }
public static string LogInOk { get; set; }
//Control de acceso
public static bool IsLogged { get; set; }
public static string MsgLogin { get; set; }
public class SQLAdminModel
public string Admin { get; set; }
public string Pass { get; set; }
public class SQLDateModel
public Guid Unicod { get; set; }
public string Url { get; set; }
//Datos del grid
public static string Lista { get; set; }
public class SQLUserModel
public string User { get; set; }
//Datos del grid
public static string Consulta { get; set; }
public static string Tabla { get; set; }
public class SQLURLModel
public static Guid Unicod { get; set; }
public static string Url { get; set; }
//Datos del grid
public class SQLUpdateModel
</textarea>
METAS
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title>@ViewBag.Title</title>
@*<!-- Ignite UI Required Combined CSS Files -->
<link href="~/CSS/themes/infragistics/infragistics.theme.css" rel="stylesheet" />
<link href="~/CSS/structure/infragistics.css" rel="stylesheet" />
<!-- Ajax & Jquery Required Combined JavaScript Files -->
<script src="~/scripts/modernizr-2.8.3.js"></script>
<script src="~/scripts/jquery-1.9.1.min.js"></script>
<script src="~/scripts/jquery-ui.min.js"></script>
<!-- Ignite UI Required Combined JavaScript Files -->
<script src="~/Js/infragistics.core.js"></script>
<script src="~/Js/infragistics.lob.js"></script>*@
<link href="http://cdn-na.infragistics.com/igniteui/2016.1/latest/css/themes/infragistics/infragistics.theme.css" rel="stylesheet" />
<link href="http://cdn-na.infragistics.com/igniteui/2016.1/latest/css/structure/infragistics.css" rel="stylesheet" />
<script src="http://ajax.aspnetcdn.com/ajax/modernizr/modernizr-2.8.3.js"></script>
<script src="http://code.jquery.com/jquery-1.9.1.min.js"></script>
<script src="http://code.jquery.com/ui/1.10.3/jquery-ui.min.js"></script>
<script src="http://cdn-na.infragistics.com/igniteui/2016.1/latest/js/infragistics.core.js"></script>
<script src="http://cdn-na.infragistics.com/igniteui/2016.1/latest/js/infragistics.lob.js"></script>
<!-- Ignite UI Loader JavaScript File -->
<script src="http://cdn-na.infragistics.com/igniteui/2016.1/latest/js/infragistics.loader.js"></script>
<!-- CSS CREADOS -->
<!-- Para Administracion -->
<link href="~/CSS/Admin/Index.css" rel="stylesheet" />
<!-- Para Home -->
<link href="~/CSS/Home/LoginAdmin.css" rel="stylesheet" />
<!-- Para Vistas Compartidas -->
<link href="~/CSS/Shared/_Footer.css" rel="stylesheet" />
<link href="~/CSS/Shared/_Header.css" rel="stylesheet" />
<link href="~/CSS/Shared/_Layout.css" rel="stylesheet" />
<link href="~/CSS/Shared/Error.css" rel="stylesheet" />
<link href="~/CSS/Shared/Lockout.css" rel="stylesheet" />
</textarea>
HEADER
Layout = null;
<div id="login">
@if (ECOMMERCE_API.Models.AdminModel.IsLogged == true)
<div id="DivTituloWeb">
<h1 id="Titulo">@ViewBag.Title</h1>
</div>
<div id="container_menu">
<ul id="main_menu">
<li id="mi_who"><a href="/Admin/Index">Gestión de usuarios</a></li>
<li id="mi_who"><a href="/Admin/ListUrl">Gestión de url</a></li>
</ul>
</div>
<div id="LogOut">
<a id="ColorLoginSalir" href="/Home/LogOut">Salir</a>
</div>
else
{ <div id="LogOut"><a id="ColorLoginSalir" href="/Home/LoginAdmin">Login</a></div> }
<div style="clear:both"></div>
</div>
</textarea>
AND THE VIEW
INDEX
ViewBag.Title = "Gestión de Usuarios APP";
<div id="divUserTable">
<table id="UserTable"></table>
@*<script src="http://www.igniteui.com/data-files/nw-products.js"></script>
<script type="text/javascript" src="ig_ui/js/infragistics.loader.js"></script>
<script src="scripts/jquery.min.js" type="text/javascript"></script>
<script src="~/JS/infragistics.js" type="text/javascript"></script>
<style src="~/CSS/infragistics" type="text/css"></style>
<script src="scripts/ig_ui/js/modules/infragistics.ui.grid.updating.js" type="text/javascript"></script>*@
<script>
//$.ig.loader({
// scriptPath: "{IG Resources root}/js/",
// cssPath: "{IG Resources root}/css/",
// resources: "igGrid.Updating"
var Produc =@Html.Raw(ECOMMERCE_API.Models.SQLUserModel.Consulta)
$(function () {
$("#UserTable").igGrid({
primaryKey: "uniCODOBJ",
columns: [ @Html.Raw(ECOMMERCE_API.Models.SQLUserModel.Tabla)],
dataSource: Produc,
dataSourceType: "json",
width: '100%',
tabIndex: 1,
autofitLastColumn: false,
autoGenerateColumns: false,
applySortedColumnCss: false,
renderCheckboxes: true,
responseDataKey: "results",
autoCommit: false,
allowGroupBy: false,
features:
{ name: "Sorting", sortingDialogContainment: "window" },
{ name: "Selection" },
{ name: "Paging", pageSize: 10 },
{ name: "Resizing" },
{ name: "Filtering", type: "local" },
name: "Updating", enableAddRow: true, editMode: "row", enableDeleteRow: true,
generatePrimaryKeyValue: function (evt, ui) { ui.value = getTempKey(); },
columnSettings:
{ columnKey: "uniCODOBJ", editorOptions: { readOnly:true } },
{ columnKey: "Usuario", editorOptions: { type: "string", disabled: false } },
{ columnKey: "Password", editorOptions: { type: "string", disabled: false } },
{ columnKey: "Url", editorOptions: { type: "igCombo", disabled: false , dataSource: "json"} },
$("#saveChanges").bind({
click: function (e) {
$("#UserTable").igGrid("saveChanges");
function saveChanges(){
alert("hola");
var updates, customersLookup = [], loadingIndicator;
$(function () {
var grid = $("#UserTable"), comboDataSource = {};
//comboDataSource = grid.data("igGridUpdating").options.columnSettings[3].editorOptions.dataSource;
comboDataSource = @Html.Raw(ECOMMERCE_API.Models.SQLDateModel.Lista);
for (var i = 0; i < comboDataSource.length; i++) {
customersLookup[comboDataSource[i].ID] = comboDataSource[i];
$("#saveChanges").igButton({ labelText: $("#saveChanges").val(), disabled: true });
$("#undo").igButton({ labelText: $("#undo").val(), disabled: true });
$("#redo").igButton({ labelText: $("#redo").val(), disabled: true });
//loadingIndicator = new GridModalLoadingIndicator(grid);
//grid.on("iggriddatabinding", function (e, args) {
// loadingIndicator.show();
//grid.on("iggriddatabound", function (e, args) {
// loadingIndicator.hide();
grid.on("iggridupdatingrowdeleted", function (e, args) {
$("#undo").igButton("option", "disabled", false);
$("#saveChanges").igButton("option", "disabled", false);
grid.on("iggridupdatingrowadded", function (e, args) {
grid.on("iggridupdatingeditrowended", function (e, args) {
if (args.update) {
$("#undo").on('igbuttonclick',
updates = $.extend({}, grid.data('igGrid').pendingTransactions());
$.each(updates, function (index, transaction) {
grid.igGrid("rollback", transaction.rowId, true);
$("#redo").igButton("option", "disabled", false);
$("#undo").igButton("disable");
$("#saveChanges").igButton("disable");
return false;
$("#redo").on('igbuttonclick',
function (e) {
switch (transaction.type) {
case "row":
grid.igGridUpdating('updateRow', transaction.rowId, transaction.row, null,true);
break;
case "newrow":
grid.igGridUpdating('addRow', transaction.row, true);
break;
case "deleterow":
grid.igGridUpdating('deleteRow', transaction.rowId, true);
break;
$(this).igButton("disable");
$("#saveChanges").on('igbuttonclick',
function (e) {
grid.igGrid("saveChanges", function saveSuccess() {
//loadingIndicator.hide();
//loadingIndicator.show();
return false;
grid.on("iggridupdatingdatadirty", function (event, ui) {
grid.igGrid("commit");
//saving local changes to the datasource when sorting
return false;
function lookupCustomer(id) {
return customersLookup[id].CompanyName;
function getTempKey()
var key;
key = new Guid();
return key;
</script>
@*<input type="button" id="saveChanges" value="Save Changes" />*@
<input type="button" id="saveChanges" class="button-style" value="Save Changes" />
<input type="button" id="undo" class="button-style" value="Undo" />
<input type="button" id="redo" class="button-style" value="Redo" />
</div>
</textarea>
Please could you tell me where my mistake and as I could afford it? many thanks
