I'm using an Infragistics v.13.2 igGrid in an MVC website. I have a problem with the modal dialogs of the grid, which appear when clicking Column Chooser, Sort on Multiple, or other similar features. The modal dialog is displayed and appears to be working correctly, but the page freezes when I click or hover the Apply or Cancel button of the modal dialog.
I investigated the problem, and I see that an endless recursion happens here (Chrome inspector reports Maximum call stack size exceeded), see attached screenshot.
By examining the error message it seems that apparently the mouseover event handler calls itself, creating an endless recursion (see highlighted row).
Do you have any idea what could possibly be wrong here? We use several igGrids in the project and this error is present in all of them.
regards,
Peter
Hello Peter,
I am glad that you find this suggestion helpful.
Hi Miro,
Thanks for your help, upgrading to jQuery UI v11.4 solved the problem perfectly.
Hi Peter Molnar,
Please use another version of jquery-ui in your sample(btw you have referenced 2 different versions of jQuery - my advice is to use only one version) - I've tested it with 1.11.2. For example in _Layout file it works properly with this configuration:
@Scripts.Render("~/bundles/jquery") @Scripts.Render("~/bundles/jqueryval") @Scripts.Render("~/bundles/bootstrap") <script src="@Url.Content("~/Scripts/modernizr-2.6.2.js")"></script> <script type="text/javascript" src="https://code.jquery.com/ui/1.11.2/jquery-ui.min.js"></script>
I hope this will help.
Miro Hristov
Thank you for providing me your sample. I am currently looking into this matter for you and I will keep you posted on my progress.
Please feel free to contact me if you have any additional questions regarding this matter.
Hi, in the meantime I've tried to update Infragistics to the latest version, but the error still persists.
