I am using MVC iggrid(Single column sorting), through which user will be allowed to add row with the data.(4 columns --> a1,a2,a3,a4)
a1 column has dropdowlist, a2, a3,a4 are integers (which can be left blank)
The issue is, once adding 1 row data say
xyz 12 blank blank
Now performing sort on blank column by clicking on header, the whole row disappears and again clicking on any header it reappears.
I tried it by proving all the data without any blanks, still the same issue.
More over it is not consistent(tried in IE11 and chrome).
Can any one suggest something so that it works fine.
Thanks in advance
Shirisha
Hello Shirisha,
Thank you for using Infragistics forums! It has been a while since you posted but if you are still looking for assistance with these matters I'll be glad to help.
I created a small sample using the information provided but couldn't reproduce the issue. Please, let me know which version of Ignite UI you are using so I can investigate this further.
Best regards,
Stamen Stoychev
