Hi everybody,
has anyone a good example for a search-box function in hierachical grid? I have one parent-band and one child-band.
At the end, my code crashes a the bold marked code "row.cells", see below.
//Events:
$("#btnSearch").igButton({ labelText: $("#btnSearch").val() }).click(function () { findRows($("#txtSearch").val()); }); $("#btnClear").igButton({ labelText: $("#btnClear").val() }).click(function () { clearSearch(); }); function findRows(searchValue) { parentGrid = $("#WebHierarchicalDataGrid1").igHierarchicalGrid("rootWidget"); if ($.trim(searchValue).length > 0) { for (var rowIndex = 0; rowIndex < allParentRows.length; rowIndex++) { if (searchCells(allParentRows[rowIndex], searchValue)) { if (!$("#hierarchicalGrid").igHierarchicalGrid("expanded", allParentRows[rowIndex])) { $("#hierarchicalGrid").igHierarchicalGrid("expand", allParentRows[rowIndex]); } } else { if ($("#hierarchicalGrid").igHierarchicalGrid("expanded", allParentRows[rowIndex])) { $("#hierarchicalGrid").igHierarchicalGrid("collapse", allParentRows[rowIndex]); } } } } else { clearSearch(); } } function searchCells(row, searchCellValue) { for (var cellIndex = 1; cellIndex < row.cells.length; cellIndex++) { var cellValue = " " + $(row.cells[cellIndex]).html() + " "; if (cellValue.toLowerCase().indexOf(searchCellValue.toLowerCase()) >= 0) { return true; } } return false; } function clearSearch() { for (var rowIndex = 0; rowIndex < allParentRows.length; rowIndex++) { if ($("#hierarchicalGrid").igHierarchicalGrid("expanded", allParentRows[rowIndex])) { $("#hierarchicalGrid").igHierarchicalGrid("collapse", allParentRows[rowIndex]); } $("#inpSearch").val(""); } } });
Please, have in mind that we no longer support version 11.2 as indicated here: http://ko.infragistics.com/support/product-lifecycle so I may not be able to provide adequate help with this matter.
With this said, I looked through igHierarchicalGrid's code for 11.2.2045 and it doesn't have a method "allRows" defined. This is a method from igGrid's API. Since you are using an older jQuery UI version, this inaccurate API call probably fails silently. You should try changing igHierarchicalGrid with igGrid when defining allParentRows.
Best regards,
Stamen Stoychev
Hi Stamen,
forgot something:
definition of allParentRows is: allParentRows = parentGrid.igHierarchicalGrid("allRows");
Is that the devil of it? See bold letters.
Regards
here all definitions:
<link href="http://cdn-na.infragistics.com/jquery/20112/2045/themes/min/base/ig.ui.min.css" rel="stylesheet" type="text/css" /> <link href="http://cdn-na.infragistics.com/jquery/20112/2045/themes/min/ig/jquery.ui.custom.min.css" rel="stylesheet" type="text/css" /> <script src="https://ajax.googleapis.com/ajax/libs/jquery/1.4.4/jquery.min.js" type="text/javascript"></script> <script src="https://ajax.googleapis.com/ajax/libs/jqueryui/1.8.13/jquery-ui.min.js" type="text/javascript"></script> <script src="http://cdn-na.infragistics.com/jquery/20112/2045/js/combined/min/ig.ui.min.js" type="text/javascript"></script> <script type="text/javascript" src="infragistics.core.js"></script> <script type="text/javascript" src="infragistics.lob.js"></script>
When I enter the procedure "searchCells(....)" an exception occurs in the for-statement "for(...; cellIndex < row.cells.length;...)" The message I've received is a javaScript runtime error. If I look to the object row it seems to be ok. But not rows.cells - it is undefined. At this point the code crashes.
Which jQuery is missing, what do you think?
Thank you for using Infragistics forums!
From what I can see row is a member of allParentRows which is not defined in the code you pasted. My best guess is that allParentRows is actually a jQuery object and the code doesn't iterate it correctly.
Try changing
to
if (searchCells(allParentRows.eq(rowIndex), searchValue)) {
If you could provide me with the code responsible for assigning the value for allParentRows, I should be able to help further.
Please, let me know if you have any other questions or concerns!
