Observable is not getting populated when igcombo rendered first time. See selected actor is empty is this fiddle example http://jsfiddle.net/manishdalal2/9mka5qjp/ . Also same issue when you remove element from combo.
Hello Dalal,
Thank you for your patience.
Please take a look at the working sample from our website: http://jsfiddle.net/egazzbg9/.
and this line:
this.selectedActor = ko.observableArray([self.actors()[0].id]);
This is the correct actor initiliziation when you have a combo in dropdown mode.
I cannot reproduce the issue you mentioned when you remove an element. Could you elaborate further on that?
I am looking forward to hearing from you.
