Is there any option for Toggleswitch for web page using javascript html Thanks in advanceRobin Bronston
Hi Robin Bronston,
I asked for assistance related to the initial issue. For better consistency and history tracking Ingragistics policy obligates to post only one issue per post. I have reviewed your last requests and found that they are not related to the "switch" issue. So I would like to ask you to create separate post for them.
Have a nice day!
Ok Thanks Petko if possible to help me the below two links?
http://ko.infragistics.com/community/forums/p/108654/511624.aspx#511624http://ko.infragistics.com/community/forums/p/108641/511542.aspx#511542ThanksRobin Bronston D
Please let me know whether you need any further assistance!
Hi Petko Petkov, Thanks you for your reply.I will check with that link and use it.Thanks Robin Bronston D
Thank you for posting in our community!
The creating of "toggle switch" or just "switch" is easy to achieve, but it is not include into the IgniteUI suite. It is include in our open source Js-blocks suite which is angular 2 based - https://github.com/IgniteUI/igniteui-js-blocks/tree/master/src/switch.
If you do not use angular 2 and want native js implementation of the "switch" you can create it for your self in 2 simple steps: How TO - Toggle Switch.
Hope this will handle your case.
