245
Iggrid reloading
Environment: Angular2/Bootstrap/Webpack
I want to reload Iggrid component on change on click on button which is outside of component. I give try to using below code, but it is not working. Can you please provide me any example of angular2 and iggrid where we can refresh grid on click of out side button.
Code used to destroy grid
in class:  {
gridMethods: IgGridMethods
this.gridMethods.dataBind(true);
Things i have in gridOptions is as below,
1)datasourceurl
2) autofitLastColumn
3) autoAdjustHeight
4) renderCheckboxes
5) isfilterActive
6) autoCommit
7) responseDataKey
8) autoGenerateColumns
9) dataSource: []
10) columns: columnFun()
11) dataSourceUrl: URL
12) primaryKey
13) dataBinding: function
  • 5513
    Thank you for using Infragistics forums!
    Calling methods on Ignite UI controls needs to be done in the jQuery UI way. So instead of:
    try this:
    $("#" + this.id).igGrid("dataBind");
    (assuming you are storing the id of igGrid's table in the id prop)
    I hope this helps! Please, let me know if you have any other questions or concerns!
    Best regards,
    Stamen Stoychev
