I noticed that when you use RowSelectors and Sorting feature in a grid, each time you click in the select all checkbox in the grid header there appears a an error in the browser's debug console.
I don't know if this error has any negative side effets.
infragistics.lob.js:438 Uncaught TypeError: Cannot read property 'replace' of undefined at t.(anonymous function).(anonymous function)._handleFocusKb (http://cdn-na.infragistics.com/igniteui/latest/js/infragistics.lob.js:438:9718) at t.(anonymous function).(anonymous function)._handleFocusKb (http://code.jquery.com/ui/1.10.3/jquery-ui.min.js:5:5028) at HTMLTableCellElement._focusHandler (http://cdn-na.infragistics.com/igniteui/latest/js/infragistics.lob.js:438:6876) at HTMLTableElement.dispatch (http://code.jquery.com/jquery-1.9.1.min.js:3:28337) at HTMLTableElement.v.handle (http://code.jquery.com/jquery-1.9.1.min.js:3:25042) at Object.trigger (http://code.jquery.com/jquery-1.9.1.min.js:3:27423) at Object.simulate (http://code.jquery.com/jquery-1.9.1.min.js:3:30815) at HTMLDocument.r (http://code.jquery.com/jquery-1.9.1.min.js:4:1788)_handleFocusKb @ infragistics.lob.js:438(anonymous) @ jquery-ui.min.js:5_focusHandler @ infragistics.lob.js:438dispatch @ jquery-1.9.1.min.js:3v.handle @ jquery-1.9.1.min.js:3trigger @ jquery-1.9.1.min.js:3simulate @ jquery-1.9.1.min.js:3r @ jquery-1.9.1.min.js:4
Here is a demonstration: http://jsfiddle.net/1uqtf6xf/
This is fixed and currently awaiting release in the next service release. Which is scheduled currently for March 24th:
http://ko.infragistics.com/support/service-releases
Has there been any resolution for this bug?
We just upgraded to IgniteUI 16.2 from 15.2 and now we see this error.
We use sorting and multiple selection with the header checkbox quite extensively and we need to deploy next month.
Note that 15.2 did not have this issue.
thanks,
wvusaf
I have submitted this for further investigation (230508) and have created a private case (CAS-180-144-N0K9N9) where I will provide you with further information.
