I try to make grid with multiheader column and hierarchical grid. I create multiheader column grid with razor helper and hierarchical grid from controller. But when I show date, it always -1 from data that I send. For example, data source send to browser with value /Date(1456765200000) but it shows as 29 Feb 2016.
If I remove a few lines about multicolumn header in grid, date shows correctly.
It happen when I use either Multicolumn Header Grid or normal grid child in Hierarchical Grid.
Is there any solution?
Thanks.
Hello Johnny,
Did you change the format in the column definition to the necessary one? For example:
columns: [ { headerText: "Product ID", key: "ProductID", dataType: "number" }, { headerText: "Product Name", key: "Name", dataType: "string" }, { headerText: "Product Number", key: "ProductNumber", dataType: "string" }, { headerText: "Date", key: "Date", dataType: "date", format: "dd MMM yyyy" }]
If this is done and it still does not work please provide me with a working sample, so I can investigate the issue.
Regards,Ivaylo HubenovEntry-level developer
Still no luck. Deleting dateDisplayFormat in editor, the result is same. I choose 3 jan 2017 and it become 1 march 2017. I did it in child grid of hierarchical grid.
Please try setting the format of the date column to "dd MMM yyyy".
I am attaching a sample, where this is done. Please test it and let me know how it went.
Hmm thankyou, but I already solved it with adding "enableUTCdates false".
Another problem is when I editing date with datepicker in child of HierarchicalGrid, I set DateInputFormat as "dd/MM/YYYY" and DateDisplayFormat as "dd MMM yyyy" it often lead to false date. For example, new column is empty and I pick 3 Jan 2017. Then it fill as 1 March 2017.
But, if I set DateInputFormat as "date" and DateDisplayFormat as "dd MMM yyyy", it shows the correct date.
Any solutions?
Regards.
Thank you for contacting Infragistics support!
Please provide me with a sample, since I could not reproduce your issue.
Thanks in advance,Ivaylo HubenovEntry-level developer
