I work on a website that contains a header, a navbar and then the grid and a footer below. The space left for the grid is about 75% of the total height. I try tho adjust the grid height, that there only is one slider on the right side of the grid and not a socond one for the complete web page.
width 100% is working, but when I try to use 75% for height it does not work, it olny works with px:
$("#columnLayout1").igLayoutManager({ }); $("#THB_LivetickerGrid").igGrid({ dataSource: datacleaned, width: "100%", height: "75%", autoGenerateColumns: false, columns: [ {..........
best Andy
Hello Andreas,
When the igGrid's height is set in percent its height is calculated, based on its parent element. Setting height to its parent element will get the percent height value to work. For example:
<style> html, body { height: 100%; }</style> //code...<body> <table id="THB_LivetickerGrid"> </table></body>
I am attaching a sample, demonstrating the code above.
Please feel free to contact me if you have further questions.
Best regards,Ivaylo HubenovEntry-level developer
