I work with iggrid and I have a very annoying problem with update url od grid. I try to modify the update url with javascript but it doesn't change the grid's url.
Here is my grid:
$('#man-grid-js').igGrid({
primaryKey: "SId",
autoGenerateColumns : false,
enableUTCDates : false,
localSchemaTransform : true,
renderCheckboxes: true,
updateUrl: '/Manual/SaveManual',
columns: [
{ headerText: "SId", key: "SId", dataType: "string", width: "15%" },
{ headerText: "SDate", key: "SDate", dataType: "date", width: "15%" }
features: [
editMode: 'cell',
startEditTriggers: 'click',
enableDeleteRow : true,
enableAddRow : true
This grid has: '/Manual/SaveManual' as updateUrl
When I submit the form, I have to add an additional parameter to the url like '/Manual/SaveManual?type=12' and this additional parameter is calculated before sending.
I have my javascript to change the update url as below:
var grid = $("#man-grid-js");
var updateUrl = grid.igGrid("option", "updateUrl"); => I get '/Manual/SaveManual
updateUrl = updateUrl + "?type='" + selectedValue + "'"; => change to '/Manual/SaveManual?type=' + selected value
grid.igGrid({ updateUrl: updateUrl })
grid.igGrid("saveChanges", function saveSuccess(data) ..... => This doesn't recognize the new url but still takes the old one
Is that an infragistic bug or I did some mistake?
Thank you for your help
Hello cem,
You may try changing the update url on urlParamsEncoding event: http://www.igniteui.com/help/api/2016.2/ig.datasource#options:settings.urlParamsEncoding
Please let me know if this works for you.
Tsanna
Just for more information:
I use mvc and I have my action as below:
public ActionResult SaveManualTextbox(string type)
When I change manually the updateUrl it doesn't recognize the updateUrl.
I check with chrome and I always see that it try to post to the base url.
To summary:
Before change url it post to '/Manual/SaveManual'
After change url it still post '/Manual/SaveManual' instead of '/Manual/SaveManual?type=12'
