55
Rendering igCombo with igupload
I want to render igCombo against each file when i add them using igUpload. The idea is that when user presses the add button and selects the images, an igCombo is rendered in front of each file where the user can put some additional information before uploading them. Is this possible to be done using igUplaod
  • 23953
    Hello Khawaja,
    There is no easy way to achieve this. It will require a lot of custom logic.
    Here is what you need to do if you want to try implementing it by yourself:
    1. Handle the igUpload.fileSelected event and find the DOM node under igUpload widget where you want to put the combo.
    2. Insert a new "input" element and instantiate igCombo on it
    3. Follow the "Sending additional data from the client to the server" topic to send the data from the combo to the server
    Best regards,
    Martin Pavlov
    Infragistics, Inc.
