Is there a way to unsort or reset sort on igPivotGrid?
There is no public API that you can use to achieve that. However you can use a private variable "_tableView" like this:
function resetSort() {
var pivot = $("#pivotGrid").data("igPivotGrid");
pivot._tableView.levelSortDirections([]);
pivot._tableView.columnSortDirections([]);
pivot._tableView.initialize();
pivot.updateGrid();
Here is a Fiddle: http://jsfiddle.net/ef91c50o/2/
Note: As this approach uses an internal variable, it might not work in future versions.
Best regards,Martin PavlovInfragistics, Inc.
