25
categoryX use date string
We face the following problems how to fix that like showing in sample snapshot?
  1. How to set date string for categoryX?
  2. Why the x axis does not display properly?
  3. Why the time of currData is different from the time of currData1, but the chart looks the same?
$(function () {
var currData = [{
Date: "\/Date(1487920800000+0800)\/",
Value: 1
Date: "\/Date(1487921400000+0800)\/",
Value: 2
Date: "\/Date(1487922000000+0800)\/",
Value: 3
Date: "\/Date(1487922600000+0800)\/",
Value: 4
Date: "\/Date(1487923200000+0800)\/",
Value: 5
var currData1 = [ {
Value: 6
Value: 7
Date: "\/Date(1487923800000+0800)\/",
Value: 1
$("#container").igDataChart({
width: "500px",
height: "500px",
dataSource: currData,
axes: [{
type: "categoryX",
formatLabel: function (item) {
var val = new Date(parseInt(item.Date.substr(6)));
ret = val.getHours();
ret += ":";
ret += val.getMinutes();
ret += ":";
ret += val.getSeconds();
return ret;
label: "Date",
labelAngle: 45,
labelExtent: 50,
markerType: "circle",
interval: 600
type: "categoryX",
ret += ":";
ret += ":";
return ret;
label: "Date",
labelVisibility: 'collapsed',
interval: 600
type: "numericY"
series: [{
title: "Test Series1",
type: "line",
xAxis: "xAxis",
yAxis: "yAxis",
valueMemberPath: "Value"
title: "Test Series2",
type: "line",
dataSource: currData1,
xAxis: "xAxis1",
yAxis: "yAxis",
horizontalZoomable: true,
verticalZoomable: true,
windowResponse: "immediate",
overviewPlusDetailPaneVisibility: "visible"
  • 960
    Suggested Answer
    Hello Liao Hao-Hsiang,
    Thank you for posting to our forum.
    categoryX treats each data in order in equal distance. That means, the first data in datasource is the first data and the second data is the second data. And interval also works in the same way.
    For example, in your datasources, currData's first data is
            Value: 1
    and currData1's first data is
            Value: 6
    Therefore, these two datapoints are treated as the data and plotted on the same X position.
    And you set interval to 600. That means labels are displayed every 600 data. That's why only the first label is displayed.
    If you want to make igDataChart take Date values into consideration as X values, you should use categoryDateTimeX or numericX axes. Whichever you use, you need to convert the serialized date strings to appropriate types before you bind JSON datasource to igDataChart; convert them to date type values if you use categoryDateTimeX and to number type values if you use numericX.
    You can see a similar discussion in http://ko.infragistics.com/community/forums/t/75280.aspx
    Best Regards,
    Noriko I.
    Developer Support Engineer
    Infragistics, Inc.
  • 25
    Suggested Answer
    The attachment is a sample snapshot
