45
igHierarchicalGrid load on demand without oData
Hi there,
I am trying to implement an hierarchical grid with jQuery Load on Demand, but I want to do it without oData.
 Following http://ko.infragistics.com/community/forums/p/94782/468676.aspx#468676 , I tried handling the igGrid.dataBinding event and in the event handler I set the dataSource option to a URL I constructed, as follows:
$(document).on("iggriddatabinding", function (evt, ui) {
if (!ui.owner.element.hasClass("ui-iggrid-root")) {
var parentRowId = ui.owner.element.parents("tr[data-container='true']").prev().data("id"),
parentGrid = ui.owner.element.parents("table.ui-iggrid-table").data("igGrid"),
parentRowData = parentGrid.findRecordByKey(parentRowId);
var dataSourceUrl = "http://" + localHost + rootDir + "api/exception/ex?defName=" + parentRowData.defname;
ui.owner.options.dataSourceUrl = dataSourceUrl;
The URL points to a web api controller in the same project, which in turn calls a remote Web API.  I don't have the option of implementing IQueryable in the web api.
While debugging, I tested the resultant URL in Fiddler, which works fine, but when I execute the page, I get the following error when I expand the row:
"There was an error parsing the JSON data and applying the defined data schema: Cannot read property 'Metadata' of null"
Any help would be greatly appreciated, I need this hierarchical grid to work ASAP.
